The rail pressure dropped another 5 lbs in the last half hour. I know it will go to 0 lbs, because that's where it was when I started this. No rail pressure at all. Jumped the Fuel pump and built it up to 36. Now at 14.
well an injector is just a silonoid. an electro magnet that when powered up pushes or pulls a small metal rod. if it was shorted it may not open the injector completly, and if open will not open the injector at all. have you checked for vacume leaks?
So far I haven't been able to find any. I replaced the lower intake manifold gasket not all that long ago. One thing I didn't mention a few posts age is that if I remove the vacuum line behind the throttle body (red one, on top) the idle increases and smooths out.
And I have something buzzing by the air filter box. Thought it was the starter solenoid. Then I thought it was the new EGR vacuum Control, Now I am thinking it is one of the Relays. Has been hard to pinpoint.
its probably a relay. my 86 had a relay that would buzz for a few seconds after i turned it off. never gave me any trouble. check for a vacum leak. my 86 had a crack in the line that goes to the brake booster and it had an erratic idle.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
