TayCo 7s
- Aug 17, 2007
- Age
- 36
is the 2.9 bellhousing bolt pattern on the engine the same as the one of a 4.0 sohc??
is the 2.9 bellhousing bolt pattern on the engine the same as the one of a 4.0 sohc??![]()
Not true. When i put the M50D-R1HD (out of a '03 FX4 Level II) in my '97 4.0 OHV, EVERY bell housing bolt matched up to the 4.0 OHV; that means that a 2.9 and the SOHC are the same.No, not exactly.
the 2.9 and the 4.0OVH are exactly the same
On the 4.0SOHC ONE bolt hole has been moved (but if you ignore that one bolt the bellhousings will still mate either way)
AD
why do you ask?you don't want to use a 2.9l tranny unless its a m5odis the 2.9 bellhousing bolt pattern on the engine the same as the one of a 4.0 sohc??![]()
