- Aug 11, 2007
- Age
- 69
- Ontario, Canada
- Automatic
- My credo
- Love Thy Neighbor
Ok, pulled the carb off and apart. Part of the problem was the gasket on the power valve, was leaking, fixed that. Reinstalled carb. Still pumps gas straight through the carb.I'm thinking that the float is set too high and the electric pump is pushing the gas through the jets before it has a chance to shut off the fuel flow??? Needle and seat looked ok, not dirty. What size jets should I have in the 350 to run it on my 2.3.
Pretty sure it is in the carb not the pressure on the fuel pump as I hooked up an old Motorcraft 2150 and the pump does not push gas straight thru the carb like the holley does.
Any help on my problem is appreciated.
Sounds like there is a carb problem, but not sure about the jet size on the Holley 350. If you just paid someone to rebuild it you might want to ask them what the problem is...sounds like the needle is blown out though...or like you said the float is set too high...the guy who rebuilt it should know how what to look for though...
