- Mar 23, 2026
- Yakima
- State - Country
- N/A
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0 V6
- Manual
- Tire Size
- 235/85/r16
Have been chasing 4x4 issue with this truck for weeks, replaced all fuses, shift motor, replaced switch in dash, and finally the GEM module. 4x4 lights have only came on once, right after replacing the gem, reconnecting the battery and starting the truck. 4x4 hi and low both worked for about 2 minutes while the truck was relearning its idle. Then the 4x4 lights turned off and would no longer switch back to 2wd. Unhooked battery and nothing, unplugged and replugged in new GEM, and same thing, work for 2 minutes then gone. Now the 4x4 will not switch, or light up even after disconnecting and reconnecting battery and the GEM. What else could the problem be? I wouldn't think its the relays in the dash because 4x4 lights are not flashing? Any help please? Thank you!
