After doing an Explorer 8.8 swap and M5R1 manual trans swap, my speedometer no longer works. The tach DOES work. I checked all fuses and both speed sensors are new. What else can it be?
Speed sensor that goes into trans... check the plug, sensor itself and the gear inside. A single small bolt holds a little fork like bracket, then you just pull it out. Abs sensors have nothing to do with the speedometer on your ranger
Is the gear missing?
