Now for the driver's side. This side was especially rusty. Check out that brake dust shield (or what's left of it):
The driver side frame rail (note the crappy rusty brake lines along the top of the frame, more on that in a little bit...)
Driver side coil bucket. You can see several rust holes in it. Worse than the passenger side:
The radius arm bushings on both sides were bad, but especially the driver side:
The driver side bushing was so bad for so long, the radius arm rubbed against the bracket and deformed the hole. This hole is supposed to be perfectly round:
I have a new bracket for this side that I'll be installing soon.
Driver's side axle beam all painted and ready to be reinstalled, center stub shaft painted with new u joint installed, and differential waiting for new axle seals.
I cleaned and painted the original hubs and mounted them to new rotors with new wheel studs:
And ABS rings reinstalled:
And like I said I replaced those crappy brake lines with new nickel copper alloy lines. Here they are coming out of the ABS unit:
The coil bucket mounts to the immediate right of them. I had to make sure there was enough clearance for it. It's a really tight fit, but they fit in there like a glove. I have the new bucket installed, but no pic of it yet.
My new brake pads showed up yesterday. I have these Hawk HPS pads on my Accord, and they're fantastic. Best pads I've ever used. I knew I had to get a set for the Bronco:
That's it for now. I have to pick up an axle seal from the store tomorrow, then I can get going on reinstalling the front diff and driver's axle beam. Until then, I'm kind of at a standstill. More progress this weekend.
