1993 Splash build
Sway bar WAS connected. I need to fill the front diff with oil, finish the alignment and THEN the flex shots...
Is it streetable? Or do you have any plans to upgrade the stock sway bar?
Oh, it's definitely streetable. It's just a little more touchy around corners is all.
I picked up a Warn 25314 8k winch today for $300. Came with all wiring, solenoid, snatch block, roller fairlead, and controller.
Truck looks Great!! Cant wait to see those flexing shots!!
What fixed the brake issue?
That is what you get for playing with used parts.
I just spent 8 hours doing an alternator on a 2000 Ford Contour with a 2.5L DOHC. What a PITA!!.
You have to drop the strut, knuckle, CV shaft (which broke when I pulled it out), passenger side wiring harness, Y-pipe, and transmission oil lines just to remove this ****ing alternator. And to boot, everything was rusty and just a PITA to remove...
I agree they are poorly placed, but it shouldn't take 8 hours. You can get them out without taking all that apart.
:annoyed: This I know all too well. I quoted a guy for 4.5 hours (which is well above the time I THOUGHT it would take). Unfortunately, he drives this thing in the winter & never washes it. Talk about RUST. I had to remove everything just to break the damn bolts loose after soaking it in PB blaster the night before.
<3 chevy
Brink check out the build post, Lets see ya flexin like that. Waiting for more pics to surface on facebook of the event to see if anyone has any others..
:yahoo:
I need to make a little more clearance in the beam's window. Other than that, I have NO binding issues.
Looks sweet, love the tails :icon_thumby:
SVT
Looks good.
Sent from my HTC ONE S using Tapatalk 2
