nooch450
Not that super expensive, but if you're on a budget, go with the steel.
You should gusset that hitch up a little bit with some plate. Piece top and bottom will do. Keep it from bending from lateral forces (non-straight pulls).
The hitch goes through that whole 2x4x.120 tube and is welded on both sides... if that makes a difference from that your seeing....
Sent from my DROIDX using Tapatalk 2
