1991 ranger 3.0 tranny swap question?
Beljum
Boonies, Arizona
Good day to all. I have a 1991 ford ranger 3.0 & the A4LD trans is starting to give me problems. But i have a 1990 ford ranger 4.0 with a trans in better condition than my 3.0 transmission.
So my question is simply, would I be able to swap the 4.0 trans into my 3.0 ranger without any problematic side affects? are they even compatible? i know the 3.0 has the a4ld trans, does the 4.0 also have a a4ld or is it a different trans? Their both automatic's (obviously) but will i be able to just pull the trans out of each & bolt them back on to one another? I appreciate any & all the advice & information anyonr can provide.
Yes, they are both A4LD transmissions
No, the Bell housings are different to match different engine bolt patterns and starter motor placement, so they can't be swapped directly.
Bell housings can be swapped, but on automatics the rear of the bell housing is also the front case for the Main pump inside the transmission, so not a simple swap, you can do it, just read up on it first, any automatic bell housing replacement videos would have that info, they are pretty much all the same in this respect.
And, not that you asked but.... 2wd or 4x4 automatic transmissions can't be swapped, total rebuild required for that, replace main shaft
awesome thanks for the info, ya i got to looking at the bolt pattern on the 4.0 & noticed riggt away they were different than the 3.0 so i knew right there it wouldnt just bolt on like i hoped. but I found out its just my torque converter going out on my 3.0 so my next question is -
Will the torque convertor outta the 4.0 go onto the trans of my 3.0 with no modifactions or anything of that sort?
