Need help please. Someone stole my keys and I need to unlock the steering so I can move the truck, also I'm wanting to convert the regular key ignition into a push button start. Any help would be great. Thanks.
I bought mine without key, needed to drill out the lock and then was able to rotate it and replace. You can you tube where to drill. it was like a 1/8" bit to get the cylinder lock to release.
Yes, drilling is the only way and they don't make it easy, point of having a locked ignition and steering wheel is to prevent what you are trying to do
Mobile locksmith can make one from scratch, but usually not inexpensive to do that
