1990 Ranger 302 swap
For street rod type stuff ripping around town a carb is really hard to beat, I was very happy with my Edelbrock (500cfm lol) on the street for 15 years.
My biggest irritation on the street was heat soak. If I had it to do over I would entertain a Holley just to see if it would be any better in that regard.
I did look into a truck avenger for an EFI alternate... dang they are proud of those things.
The ethanol fuel is worse about heat soak and vapor lock than the older fuel formula's. Stock 2.8 in a BII I had to install a electric pump along the frame or it would die on me in city driving.
I never had a problem with my 2.8 once it was warm, arguably it was better than the Edelbrock.
However it was horribly cold blooded. It wasn't until I snagged an EVTM years after I had swapped it out that I noticed the choke was supposed to get like 7v or something weird, PO of my truck was feeding it 12v so it was pulling off way fast ;brownbag;
Originally it did have a full electric 12v choke that was controlled by a relay hooked to the computer system. When I got it, that relay had failed and someone had long ago hooked the choke to the 7v from the back of the alternator. What a mess that computer system was on the 2.8. They used it on all the 84-up 300 sixes also till they went to fuel injection.
Mine just had a wire crammed in the fuse box with a fuse.
Well when E10 boils at 135F at atmospheric pressure then you'll get that... it's pretty annoying...
Right side header pic for @tjm73. One could probably get away with a smaller cutout. I can't remember why I made mine so big.
Motor mount plates from donor Explorer:
(Left)
(Right)
That clearance is TIGHT. Thanks for the pics. Gives me food for thought.
Yeah, you can't remove the headers without lifting the engine. I had to put these in when I was dropping the engine for the final time.
Got the carb put back on and it runs great!
Over the last couple of weeks I've been replacing all of the suspension bushings, ball joints and steering linkage and installing a 3/5 lowering kit from Rick's Rangerz with the Doetsch shocks he offers. So far the ride isn't rough at all, but I only drove it 6 miles to the alignment shop.
I like the new altitude. Did you use the DJM beams up front? Are the front wheels centered in the wheel opening or are they biased to the rear a little bit. You are basically building the truck I am about to start building.
Are you running a 94-11 rear bumper? I bought one to put on my '89.
How has that eBay radiator been handling the V8? Does the truck stay nice and cool or does it ever run hot?
This is my truck. It's been lowered with just coils by a previous owner. I have to undo that and redo it right. Other than my wheels & tires and the lowering it has it's a completely stock survivor.
