- Apr 5, 2012
- New Castle, DE
- State - Country
- DE - USA
- Vehicle
- Ford Bronco II
- Drive
- 4WD
- 2.9L
- Automatic
- Total Lift
- 7?
- Tire Size
- 39.5"
Got the truck aligned, the guy said he was going to use solid bushings but what do you know, he used adjustable... I practically paid someone to do what I had already done and un-did, and he only aligned the passenger side. Oh well learn from your mistakes, im going to call them tomorrow and ask why they used adjustable. The tires still seem to point out a little at the tops. If i move the truck about 50ft forward, and check the hubs with a degree meter I read about 2 degrees positive camber. I dont know if this is the right or what not but I guess if the shop did it and didnt say anything about it being wrong it should be ok. Also discovered a hole in the one tsl looked like it was from a very small nail. So after fixing that I need to weld on the ebrake bracket and put on the new body panels and shes ready.
