1989 2.9l 4x4 swap to 1990 4.0l thats also had 4x4
Tictac1994
5+ Year Member
So i pulled a 4.0l out of a 90 and grabbed the harness and ECU and believe i grabbed the map sensor since its speed density. What is the rest i need to convert and does my 89 have trans cooler or should i pull that from the donor truck as well, both are auto's and same transmission. So pretty much what all do i need to have for the conversion. And what can i remove off my truck that wont be needed.
I already been through few threads but most of it was minimal description
:dunno:
there's no such thing as a "speed density 4.0"
The early 4.0's do have a MAP sensor but it would also have a Mass Air sensor mounted to the air box...
AD
So i am missing the maf sensor and the rest of it....i asked the owner and he said "i dont think it had a sensor" he looked lost when i said MAF i dont think he even knew what it is
AD
I replied
AD
So what output are the injectors on the 90 4.0? And do you know by chance where on the harness the maf plugs into cuz there was a few burned up connections on the harness that were already there before i showed up
