- Aug 15, 2007
- 2.3 (4 Cylinder)
- My credo
- vertical and above ground
The diaphragm is for the 'choke pulldown'. Once the engine starts, the pulldown will pull the choke plate open enough to 'run'. Vacuum in the intake gets strong enough with the engine running to overcome the choke apply spring.
Most 'idle control' motors on carbs were more 'idle control solenoids'. They projected a rod with a hex-shaped end that pushed on the carburetor throttle linkage. They were not strong enough to open the throttle plate by themself, but once the key was in the ON position, pressing on the gas pedal to set the choke(allow it to spring closed & move the high idle cam) would also prop open the throttle plate a bit.
When the key went to OFF, the solenoid relaxed, and allowed the throttle plates to close completely, thus preventing 'run on' after the ignition was disabled. Hot engines of the time would try to diesel at shutdown, and if the throttle was open the slightest, they'd keep gurgling on, and the semi-firing produced a pile of unburned emissions that was very noxious to smell(at least).
Anyway, if you have an idle control motor or solenoid, it would be connected to the linkage, or a part of the linkage alongside the carburetor. Got any pictures?
tom
tom
