1988 BII Build
you know....my buddy is a project manager at a construction company, they just built a huge factory in the eastern part of the state, maybe he can get me something.
worked on the tire carrier some tonight. got dark before i could get as far as i wanted, hopefully i can work this weekend.
welded up everything that i had tacked together
1988 BII Build
1988 BII Build
1988 BII Build
capped off the top
1988 BII Build
ground it down a bit and then put it on the truck for the night
1988 BII Build
it's actually straight!!!! lol
1988 BII Build
Looks dang good!
thanks man, it's turning out way better than i hoped it would. i just wish i had some gas or anti spatter spray. i may hit up a tractor supply this weekend and get some.
we'll see, i've been thinking about it
Nah, leave the top the way it is, that way you don't have to worry about rain, and stuff getting blown in, also if you happen to drive it to the local store, you wont have to worry about some one stealing your stuff.
Robert
posted from my laptop while sitting in the bathroom.
that's true robert, plus the pollen is awful right now, i dont want it getting all over my stuff.
as far as storage, i'm going to build a lockable metal sliding drawer to house some tools and spare parts
wow i am bored at work today
started looking at the carrier, i think i'm gonna add some bracing with 1/8" plate to carrier....just to make sure it doesnt bend or torque anywhere.
1988 BII Build
the braces in the middle will add extra support for the highlift mounts
got the latch today, much larger than i thought it was gonna be. still may fab my own, i dont know yet
1988 BII Build
got some anti spatter spray today, i cant really tell a difference, i guess the welds look a little better....i dont know
added some gussets to the tire carrier, on the bottom of each side
1988 BII Build
and one on the top
1988 BII Build
got the hole cut out for the part that actually holds the tire.....i had some oil on the metal and it didnt weld for hit. i'm gonna have to go back and grind them out and re-weld, they look awful up close
1988 BII Build
1988 BII Build
i used a gusset i had kicking around from ballistic to brace it, i like it.
went and got a spring and a washer from Ace tonight, i'm gonna try and make this work
1988 BII Build
i played around with the latch i ordered and i dont think i wanna use it
got the latch done today, works perfectly as it is and it should work even better once it's got a tire on it.
tacked everything together to make sure my idea was gonna work.
1988 BII Build
1988 BII Build
then burnt it in for good
1988 BII Build
1988 BII Build
1988 BII Build
ramp and hole for the latch to catch in
1988 BII Build
1988 BII Build
figured out why my welds were so shitty yesterday, i was using too much of the anti spatter spray, figured that out and the stuff is working way better now. it does make the welds look a little better. it still spatters a bit though.
1988 BII Build
