100 Laps on Charlotte Motor Speedway
Featured Build Threads
justonlyjohn
5+ Year Member
Hi Folks! I'm new to the forum. I own a 93 Ranger 2WD, 3.0, 5-speed manual and we have had some great times together; the best being that I got to drive 100 Laps on CMS to help dry the track. Yeah, I pegged it at 85 mph once or twice. Anyway, I love my truck and want to give it to my son who turned 16 today. I'm a DIYer and grew up in a machine shop. I've done a lot of engine work but never a transmission. I'm told the Mazda M50D-R1 is supposed to be the transmission in my truck and it isn't a tough rebuild. So, your opinions please: should I attempt to rebuild my own transmission? I believe in fixing what is broken and not just being a parts replacer!
Thanks for reading this and for any advice you can offer.
joj
I havent done one personally but if you do your homework and take your time i imagine they are pretty straight forward. I would do one myself given the opportunity. Hopefully not anytime soon lol.
Sent from my LGL16C using Tapatalk
Just got done rebuilding an M5OD a couple weeks ago, they are easy. Special tools you will need include a caliper for measuring for bearing shims, a 32mm socket, and a torque wrench...other than that it is all basic hand tools. I guess a shop press is nice for pressing bearings and races on but it can be done with a few lengths of pipe/tubing.
Contrary to popular belief you do not need a bearing puller, you can use a chisel to remove the bearings and races. The output shaft rear bearing was the only one that fought me. An air chisel makes quick work of it. And yes this is an accepted practice.
The only advice I have is to keep track of the direction that the 1-2 and 3-4 slider rings go on...they fit either way but won't work well backwards. They have a "reference dot" indicating direction...well... both sliders in mine had TWO dots, a big one and a small one, makes you wonder which way is correct. Might want to draw an arrow on them with a sharpie or something.
Also make sure that you clean everything really well, my transmission was packed full of fine metal shavings and sludge, especially in areas where oil should be flowing through... a trip through the parts washer and quick scrub with a toothbrush cleaned it all up nice.
It's easy, just do it.
One more thing, make sure you get a quality bearing kit. I got a kit through Allstate Gear on eBay and one of the countershaft bearings was so far out of spec that it could not be used. Their customer service is pretty terrible too. I did get my money back and then some but it was just a bad experience overall.
Many thanks!
I appreciate your encouragement and am going to take a shot at it. It should be a fun project with my son helping me. Lord knows when he gets wheels I'll probably hardly see him anymore since he'll be out cruising all the time. Thanks again for the advice.
what's wrong with yours?
they are known to easily exceed 300,000 miles with only fluid changes.
Perry
I let her sit too long without driving her. About four years. Thing is, after installing a new battery she started right up. Put new fuel in it and sea foam cleaner and she ran fine. Then whatever it was that happened, happened.
Featured Ranger Based Vehicle
