$100 dollar BII 2.9 blues no start.
Featured Build Threads
Northidahotrailblazer
10+ Year Member
Truck of Month
Northern Idaho
4.0L
8 inches
37"
I picked up this 1988 B2, it’s been sitting for a long time. Last guy bought it non running and was told fuel pump issues. For $100 bucks with a title. I figured why not. Got it home, threw a battery in it and found some interesting stuff done, but nothing crazy. I couldn’t hear the fuel pumps, checked relays there clicking so figured yup probably fuel pumps. So I checked spark and had none. So wanting to hear it do something. I put on a good spare TFI module on and got spark back, it will run on starting fluid. So I went to the fuel pumps. Pulled the tank down, full of rust and misery. I had a spare new tank and ordered a new low pressure pump and sending unit. Reinstalled that, no high fuel pressure still. Pulled high pressure pump down, went through my parts rigs after 3 found one good one, fuel pressure holds and is 46 psi. Cool, still no start….start testing powers and grounds, ecm has its grounds and powers. Swapped PCMs with one from my old 89. No luck, though spark was looking a little funky, so maybe pip was bad? Pulled the distributor and swapped with a good one. Still same issue, injectors aren’t injecting. So I checked for powers and grounds at the TFI both there and good. Figured maybe the Pip signal wire to the PCM is bad? Ohm’d out signal wire 1 ohm, well that’s ok, check spout wire also, 1.2 ohms…. We shit. Idk from what I can tell, I have all the powers and grounds at the PCM plug I need. Idk I’m missing something. I just wouldn’t think the injectors would be so plugged up they wouldn’t do anything. And that all 6 are bad…. I guess I can see about a noid tester and see if I am really getting signal to the injector.
I’m just out of ideas, I’m about to give up a just put this body of my SAS’d frame with the 5.0 in it. I’m just really not about v6 auto life after having my others being at least 4.0/5.0 swapped. 😎🙃
IIRC the fuel injectors are powered at key on the PCM just grounds then to fire. Check for 12v to one side of the injectors? Haynes manual says it's a solid red wire from the PCM relay. Goes out to lots of things...
Pull an injector and put 12v to it. See if it clicks. If not, could be the issue. If the last guy tried to start it without checking the tank, it's possible they're full of, well, tank.
checked a few more things, OHMs from the injectors and to the pcm is good both output ground wires. Checked for 12vs to the hot wire and it’s good.
Pulled an injector harness from another engine and built a harness lol to bypass the pcm. Only have one side hooked up, I can get it to sputter. I can hear the injectors clicking. Idk I’m gonna keep messing with it.
Thinking aloud…
If you have a fuel pressure tester and you can confirm +12v to both sets of injectors, could you manually ground each set with the key on to try to cycle them and see if the rail pressure goes down as you do that? Quick confirmation that fuel is flowing.
I didn't see it mentioned, but if the fuel tank was "full of rust and misery", you'll want to check the fuel filter too... If anything got past the filter (and it's possible... A number of years back we had a few posts on here about some chinese (I think) junk filters (even from big names like Purolator) that the inside seals had separated on), it's very possible the injectors would all be plugged too.
The fact it ran on starter fluid says the ignition is working, so has to be a fuel issue.
I think the injectors are plugged and not working. I put an adapter on the Schrader valve and I had good flow out of it. I put a harness on 5 of the 6 injectors and manually ground them and I can get it to kinda sputter but not start like starting fluid…. I don’t have an extra set of injectors anymore and I’m not wasting time/money because I have no idea how good the 2.9 or A4LD is. I decided I don’t want a chop top on my SAS b2 project. So this body will be the donor! It’s in ok shape. And it’s titled in my name now so no funky stuff I’d have to do to my chop top body. Thanks for the help everyone.
You could spray some brake clean backwards through an injector while someone fires them with a drill battery and some wire. Just an idea but may not be worth your time
Upcoming TRS Events
Featured Ranger Based Vehicle
