1 ton, caged ranger
Just ordered mine, and two LED lights to light up my cab. He hooked me up and gave me free engraving. It is about 6 wks out
1 ton, caged ranger
1 ton, caged ranger
1 ton, caged ranger
1 ton, caged ranger
1 ton, caged ranger
1 ton, caged ranger
1 ton, caged ranger
I pick up my check tomorrow
I am seriously considering buying Ruff Stuffs 3 link kit for the front right now LINKY with all of the options it is the same price as some store bought radius arms (not saying I would store buy radius arms, just making a comparison) and it comes with basically everything I need for the front except for some coilovers and shock hoops. I already would have to buy those for a radius arm setup anyways.
Anyone with a 3 linked truck that still hits the street? Not saying I will drive it on the street a ton but I want to be able to if I want to. Are links pretty streetable?
I dropped off some scrap metal a couple of days and was surprised to see that my truck only weighs 3820. That is counting all of my tools and gear except for my spare tire. Looks like I dropped a few hundo with the cage
I was surprised that my truck only weighed about 3720 pounds with me in it (so 3500 empty). How much did you get for the 350?
I will be, I don't see it being an issue with a properly set up link suspension.
Thats what I was thinking, I figure it can't be any worse than a radius arm setup. Plus it will be driven pretty infrequently. Do you happen to have the numbers/calculator from yours?
Went shopping at HF
1 ton, caged ranger
1 ton, caged ranger
1 ton, caged ranger
1 ton, caged ranger
After putting my cart together I pulled apart the trans and tcase cause someone might buy it.
1 ton, caged ranger
Also I have a question for the experts. I was planning on using a 99 dodge gasser master when I do the 1 ton swap but I have the master out of my 86 f350 gasser. IIRC it is 1 1/8 bore. Any reason I couldn't use the one I already have?
1 ton, caged ranger
1 ton, caged ranger
And i have been neglecting some maintenance stuff on my truck so I went shopping.
1 ton, caged ranger
1 ton, caged ranger
I also got stuff to wire my switch to the alternator
1 ton, caged ranger
Oh and I cleaned the workbench
1 ton, caged ranger
I wish I had a workbench to clean... :(
Over the next month I am helping a friend build his cherokee. D44 front, SF 14 bolt rear. 4.56's(?) cromo axles. lockers 36in swampers. 4.0/nv4500/203/205. 3 link front 3/4 elliptical rear. We want it done in a month, after that I will have first priority for co-dawg privileges.
Ill get some pics tomorrow
Did a little shopping, MDF, kicker 6x9's and carpet. Next payday I am buying a new deck and some wiring gear to get this all in there. I have been listening to music through one stock crappy speaker for too long right now.
1 ton, caged ranger
1 ton, caged ranger
Started building my box for the speakers. Design #1
1 ton, caged ranger
Transferred to 1/2in mdf
1 ton, caged ranger
Cut out
1 ton, caged ranger
decided I wanted it smaller because there is no point in it being so big.
Now it is 12x12x12
1 ton, caged ranger
I am about to head over to a friends to borrow a compressor and a brad nailer so I can put this thing together
1 ton, caged ranger
Cardboard is never going to hold up. It will split open the first time you crank it up. I dont care how many brads you use. :icon_rofl:
