- Nov 3, 2020
- 4.0L
- Tire Size
- 265/75/16
Hi everyone, so I’ve had my ranger for almost four years. I’ve done a decent chunk of work and add ons. I recently upgraded my rear spring packs to the 43-871HD’s and now am installing my bilstein 5100 series shocks (though they’re meant for a RWD 4in lifted, I did the research and found the compression and decompression were very similar with factory specs). Anyways to my question/Curiosity I know I have a 4x4 not a RWD that being said I have looked at replacing my front shocks and supposedly I can get a rough country full tube non-chicken stick shocks for my front end. My theoretical question is would the tube be close enough to my CV to allow it not to rub; because I found a bilstein 5100 series shock meant for a f150 and the specs fall in line with the compression and decommission of what I need and they also happen to be a few millimeters narrower in circumference of the rough county tube. Any ideas and knowledge would be great also would save me from spending almost three hundred in parts. Thanks
