Blakesgst
- Nov 5, 2009
- Automatic
Hi guys, I recently decided to do some a/c maintenance just before it got hot down in the California desert. I cleaned my evaporator behind the dash by making an access hole in the plastic box in the engine compartment. This allowed me to vacuum out all the leaves that were in there as well as use foam spray and water to rinse off the coil quite well. It is cooling/blowing nicely BUT, 80% of the air comes out of my center 2 vents above the stereo and the outer 2 vents hardly blow at all, is this common? I cant tell if those side vents on the dash can pop out, they almost look molded in, maybe there is some blockage in there someplace?
Thanks,
Blake
Thanks,
Blake
