02 FX4 Twin stick Build
Primed and painted it for the time being so it doesn't rust, still have to plate the top and add some plate to the sides yet. When it's finished it will be Bedlined.
Started making a winch mount
Looks like I'm gonna have to relocate the solenoid box under the hood so the winch will fit
Pics of progress
Made extension cables for the winch solenoid box from 2ga welding cable
Mounted the solenoid here
And I'm childish so I bought these air horns
Well it's finished, and I got new tires.
holy moly, thats cool, dont think ill make my bumper, in fact I might actually keep the one i have, im kinda growing fond of it.
but i did get new tires (BFG KO2's) and install LED bars behind my grill (looks and works AMAZING)
does your CB whip give you any trouble in its current spot? i have been thinking of adding a CB to my truck but i dont know where to put the whip
but next i have to do the clutch, flywheel, master and slave cylinders...$450 before taxes for just the parts...
Thanks. The CB whip is fine, although i I have to take it off if I go through the car wash.
Yeah that's about what it costed me to do it when I did the clutch and slave. It's not a bad job to do really.
picked these axles up, 78 bronco full width high pinion Dana 44 and a 31 spline 9" rear end. Also got a bronco/f150 steering box, bronco radius arms, coil buckets, some driveshafts and some other stuff. Only set me back $300
Got the axles apart, cleaned up and painted
FedEx guy has been to my house a lot lately
The 9" axle shafts had a groove worn in then from the seal, turns out they don't make a specific speedi sleeve for it, but I measured it and ended up using a crank shaft repair sleeve on them and it worked perfect
Baljoints and u joints installed
Picked up a manual t case with a yoke front output shaft instead of the cup type output shaft I have, scored it for $80, it has new seals too
5:13 gears and Detroit locker for the 9" rear end
And started setting up the d44 ring and pinion with 5:13s and a Detroit true trac
Sweet build! Can't wait to see more!
This is my final gear pattern, I'm pretty happy with it
Drilled out the knuckles for Chevy one ton tie rods
Front axle pretty much done
Rear axle is finished other than brakes.
And started on the radius arms
Decided to make a diff gaurd for the 9", might do a bolt on skid plate that goes along the bottom too.
Made it out of solid square stock I had laying around
Picked up a pipe bender off Kijiji and turns out it bends the solid stock pretty good too
This is a sweet build. You got those axles for a steal at $300 for the pair! Looking forward to the progress.
