02 FX4 Twin stick Build
06+ power mirrors installed
That's it, I'm sold! That looks great!
posted using smoke signals
Recently replaced a wheel bearing and u joint
Went wheeling with some local ranger guys
Picked up some 06+ fender flares for less than $100. Most likely gonna paint them all matte black
And it snowed
Recently replaced the clutch, I used a Luk clutch kit with new clutch, pressure plate, pilot bearing, throwout bearing, new Ford slave cylinder, had the flywheel resurfaced and changed the tranny fluid with Mercon V. Also replaced the tranny mount as both bolts snapped on removal. Other than that everything went smoothly.
Got some 06+ headlight corners and modded them
Did tie rod ends and serpentine belt a few days ago
And installed the headlight corners
Tryd out my new Christmas gift
And another shot of the 06+ corners
So I replaced the rear wheel speed sensor and cleared the code and its ok good now.
Also painted the 06+ flares
New sound system, bought it off my buddy, he had it in his ranger for 1 year.
Kenwood DDX470 head unit
Kicker 1200 watt amp, I removed the factory jack and put the amp behind the jack cover so it's hidden out of sight
Kicker compS 10" sub in Kicker ported box
It pounds really hard for how small it is, I'm very impressed with it
Do you still have the Alcoa wheels?
