Ring gap
TEACHER
Alabama
Anyone know what the ring gap should be for my 4.0 ohv . Adding Paxton about 6 lbs max on ported heads.Or where would a person find that info.
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
Are you running pump gas or e85 or something to that nature. Pump gas will run hotter cylinder temps but I doubt your rings will hit with 6 pounds of boost.
If you were trying to run 15 psi or something then I would go .020 top and .016 bottom my buddy ran that on a supercharged 302. Just remember the bigger the gap the more blowby.
TEACHER
Alabama
Thanks, ran them 20 thanks for the reply
Craig0320
225
Mississppi
No problem let us know how everything goes.
