bnrr
- Mar 16, 2010
- Reaction score
- 0
- Make / Model
- Ford
Happy New Year, I am not sure if I am in the right place to post my question.
I need information about a part, what is the soft tube called, the one that is connected from the air intake tube to the engine head air inlet near the oil fill cap. The tube is like a soft foam which can be squeezed, the connector part that connects to the the air intake tube is badly crack and falling apart. As a temporary fix I use black tape for now until I am able to find a replacement part,
Which is exactly I have no idea what it's called I have check eBay LMC truck and other website using keywords like air intake tube, air intake tube assembly, etc.. but no results, I have also check the local junk yard but found none. Need help as to availability online and just exactly what it is called
As it seems the part would not last for long. Oh one more thing, I do not want to replace the air intake assembly to performance assembly, don't actually need it
Unless absolutely no other choice. Thanks
