- Apr 17, 2026
- Midland
- State - Country
- TX - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 3.0 V6
- Automatic
Yes I've tried all that and still nothing. Checked for spark multiple ways, tested injector wiring with test noid, I did another cold compression test, all spark plugs out and got about 130ish on each cylinder. I might not be getting fuel pressure so checking that next.Any chance you set #1 to TDC exhaust? Regardless you should get some pops and bangs. You sure the injectors are firing? If you pull a plug after trying to start it, is it wet with gas? Have you tried spraying some flammable liquid into the throttle body to see if you get anything then?
