Distributor option
I need you guys to help me out and look at this Tech Article I posted and see if I need to add or correct anything. Right now, I feel like it's torn between being its own article and being a supplement to the Duraspark Conversion article. I feel like I need to add more information about remove the unused wiring, computer, and EGR.
Removing the old computer wiring and computer is not really necessary for things to function and run correctly after the conversion. It would be more of aesthetics type thing, "cleaning up" the mess under the hood.
So I am thinking if you wanted to include it, make sure it is at the tail end of the article, making sure the engine runs correctly before tearing stuff out. And also not to clutter up the article and make it too much to read. In other words, breaking the whole operation down in two parts, the conversion and then the clean-up with the clean-up being optional.
I noticed 2 spots that may need clarification.
The first is "them". Which them specifically? The distributor or the kit?
Distributor option
And the second is the "was as". Is it supposed to be "way as"?
Distributor option
