Yep, Another V8 Swap Is Underway!
Broosedamoose
115
South East Massachusettes
4.0L SOHC
31 x 10.5
Coming in second just makes you the first loser!
Update
Well, one of the heads is non-repairable and the block has a hairline crack! So much for all that work! :annoyed: So, since I am restoring the entire truck I am going to go with a new block. I am looking at the ATK High Performance Ford 331 Stroker short block and the BluePrint Engines Ford 5.0L 302 HO crate engine (basic Mustang replacement engine) both from Summit. The 331 is going to eat up a bunch of my budget ($4,000 with heads and cam) but if I go with the 302 I have to change the cam and that voids the warranty! I am currently leaning towards the 331 just because I can do whatever I want with the top end and more ponies of course! I am open to suggestions and would like to here what YOU would do.
Jbrown1238
6
Largo, Fl
306
None
If you are going to run the Explorer ECM with a 331 you will not only need a custom tune but will need to consider the crank balancer issue as well. Most 331's will require a 28 oz balancer and the Explorer uses a 50 oz balancer. Probably the best way around that issue is to contact Dampener Dudes and have them setup a stock 50 oz Explorer balancer for 28 oz. Seems like they charge about $150.00 for that work.
Broosedamoose
115
4.0L SOHC
31 x 10.5
Seems the general consensus is to just go with the 302 HO block and swap out the cam. It's going to void the warranty but, oh well.:dunno:
Broosedamoose
115
4.0L SOHC
31 x 10.5
So I am going with a company called MABBCO out of Tyler, TX. They are building me a custom 302 long block with high compression Hyperutectic pistons, Moly rings, Hardened connecting rod bolts, an EFI compatible cam (Duration: 270/288, Lift: .510/.520), Double Roller timing chain, all balanced and a set of assembled GT40 (not P) heads to match! With the Trick Flow intake and 75mm TB it should be 300+ HP! Can't wait to hear it fire up for the first time! I will definitely post a video. :icon_hornsup:
Broosedamoose
115
4.0L SOHC
31 x 10.5
Headers
So according to customer support at Advanced Adapters, their V8 conversion headers will work for me. Has anyone ever used them or know about them? They would be the 717044-HDR model.
Broosedamoose
115
4.0L SOHC
31 x 10.5
Well here is the power plant! Front components out for powder coating and I'm cleaning up the engine bay. Once that's done and I replace the cab mounts I'll be ready to drop it in! Taking a long time but it's being done right!
prymetime1
Nice looking set up! Looking fwd to seeing this come together.
Sent from my SM-G900V using Tapatalk
Knight1977
Hammond, La
Do you have a link for Dampener Dudes? I’m in the process of doing a 347 swap and I’m using the explorer accessories. I need to go to a 28oz. Thanks in advance.
Jbrown1238
6
Largo, Fl
306
None
I don't have a contact number for them any longer but it should be fairly easy to find online. That is where I found the number when I called them. I know a few people here who have had them do balances for them but I ended up staying with the stock stroke and using a OEM balancer.
Junglejoe
66
Columbia Missouri
6.0
Here ya go.. Same dudes I'm using..800-413-2673
I also asked him about cnc'ing a new dampener so I can switch pullies for boost.. Haven't heard back from them yet.. He was checking with people he knows
