Wondering if you gurus can help?
JMar88
El Paso TX
4 inch suspension
I have a 1988 Ford Ranger 2.9 V6 2WD and I been experiencing some serious issues. I been trying to diagnose the Issue since i first got it. I bought it on Dec 28th, first thing I did was change,Spark Plugs,Cables,Oil, cleaned the injectors,oil filter, fuel filter and rebuild transmission since it was really bad. I would try driving it when it was cold it drove perfect after heating up and couple minutes of driving it, it starts getting sluggish it hesitates to go it chokes bad and it wants to shut off. It feels like a miss fire as well. I decided to get a new MAP sensor and TPS, Also changed the IAC valve.This weekend I took the Catilyc Converter out and installed a new O2 sensor. All of this helped tremendously but issue is still there. My next step is to replace injectors or my fuel pump. This truck has the the fuel pump housing in the tank and I feel like that's a big issue. Hopefully you guys can help and let me know if you guys have experienced any of this. Oh by the way in the process of getting me a ODB1 to check codes dont have one yet! Thank you guys
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Get an ohm reading both when cold of ect and iat sensors.
Ect has two posts, temp gage has one. Ignore single post.
Also your code off your ecm if you would.
JMar88
El Paso TX
4 inch suspension
Thanks man I'll try that. I will be purchasing that ODB1 code module this weekend
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Eh? City slicker? ;brownbag;
Jumper your obd1 harness with a paperclip, run back to the cab and don't do anything but write down single digit Morse code style cryptic messages from your truck's brain. Post what the wizard tells us. We shall decipher the runes...
Have pencil and paper ready. EEC-IV waits for no one.
Takes a good 10 minutes to activate deep memory and stored codes. It's a 32 year old computer.
It. It uh... It ain't exactly an IPhone... **** it's barely a calculator. You can replace it with an arduino (child's/development board for veeeeery basic c++ learnins and prototypins) with a little know how. So. 10 mins and do it twice. I use. Legal pad and a pencil. One number per line, run down the page like you're writing in mandarin (or traditional... Can't remember). Just... Up to down, not left to right.
JMar88
El Paso TX
4 inch suspension
Sounds good herd about this trick I will try as well!
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Oh no trick. This is your Vulcan mind meld with your truck.
Soon the Canadians will swoop from the heavens and grant wisdom.
Actual photo of the TRS Canadian man-gods on their way to this post.
JMar88
El Paso TX
4 inch suspension
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Oh, and Haynes manual if you don't have one already. Crazy useful stuff, if for nothing else wiring diagrams and torque specs.
Oh! And welcome to TRS and stuff.
Furthermore,
:worthless:
Hiiiiii! I'm their resident 2.9... Um. Enthusiast? I'm wrong half the time, so, here's to hoping!
JMar88
El Paso TX
4 inch suspension
Thanks PJ412 I will be posting pictures soon lol! And yes I have ordered a Haynes manual from Rock Auto since I shop there frequently.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Good on. The 2.9 is a misunderstood engine. Euro touring car engine that was shoehorned into a pickup platform.
If fed lots o air, block coolant passages and rad flushed once a year, and kept squeaky clean (invest in a catch can and a set of valve cover grometts if yours are leaky), they run their asses off forever.
Overheating is certain death for them. Like, no second chances for your heads if 86 tm casting.
Aftermarket heads make it damn near invincible.
franklin2
1,767
Virginia
Here's a link on how to read the codes with a old needle type meter or you can use a testlight instead of the meter. No need to get a OBD1 code reader unless you would like to have one. You definitely need to get something to read the codes.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
No, you don't. That's factually incorrect. Your MIL will flash for codes as well if properly jumpered.
franklin2
1,767
Virginia
Ok, I will re-word that. You definitely need to read the codes. Though you will still need to "get" a paperclip to do it :)
ericbphoto
Overlander in development
16,635
Wellford, SC
6"
