notaprob
- Jul 26, 2012
- 0
- Wilmington, N.C.
- Ford
- Engine Size
- 4.0
Hey, I bought a 1994 ranger and and the wiper motor did not work and im not sure if it had been replaced because the wires were cut and put back together. I saw that the fuse was missing so I put it in and as soon as I did the motor started running and I heard plastic grinding and I took the fuse back out. I took the cover off of the motor and took off the plastic gear and of course it was stripped. But that is the least of my problems. The motor keeps running unless the wipers are all of the way up (vertical) then it stops.. Even with the switch in the off position, the motor will keep running unless I move the wipers vertically. Keep in mind that all of the procedures were done without the plastic gear connected to the motor and wiper. My questions are: Why does the motor keep running and why does it cease to run when the wipers are vertical?
Thanks in advance! It has been very sketchy driving in the rain and with a foggy windshield!!!
