Why you don’t run Mustang S550 wheels
MrGearhead
16
Illinois
𝔽𝕠𝕣𝕕
𝟛.𝟘
Well. I thought I was smarter than the average bear.... nope.. I picked up a set of 2012 GT wheels (18”) for my ‘06. In order to use them I need spacers. The stock lugs are 1 5/8” long so I would need spacers as thick as them. Looks like 2” is really the only option. 2” spacers will push the wheels just too close to the wheelwells.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
647
Central Indiana
The last ones pictured look like SN95 wheels to me. And yes, shorter spacers take advantage of the pockets that are often machined into the back of the hubs for stud clearance.
MrGearhead
16
Illinois
𝔽𝕠𝕣𝕕
𝟛.𝟘
Yea, they are SN95 wheels... If I want to keep running the 550 wheels I suppose I can find shorter lugs for the front.. 2” spacers look like they will fit in the rear. If I can find shorter lugs for the front I can run 1.5” spacers.
MrGearhead
16
Illinois
𝔽𝕠𝕣𝕕
𝟛.𝟘
Side note. I’m currently running a 1/4” spacer to allow the front wheels to fit.
JoshT
1,736
Macon/Fort Valley, GA
Shorter lug nuts or shorter studs? If it's lug nuts just get some basic open ended acorn lug nutss, they are about as short as you can get. If it's studs you may be able to get away with grinding them down a bit for clearance, just make sure you leave enough length to fully engage your lug nuts and preferably protrude through them by a thread or few.
Just word of caution, if using adapter style spacers (IE: spacer bolt to truck's studs then wheel bolts to adapter's studs) make sure you pull the wheel and check the torque on the adapter/spacer after a bit. It's very important. I knew I was supposed to do it, but didn't and it bit me in the a$$.
Those wheels look good on your truck BTW.
cbxer55
767
Midwest City, Oklahoma
I use bolt on adapters on the back of my Lightning, since I am now running 12.5 inch rims in the back ,up from the stock 9.5. Got to move them out to clear the springs and the e-brake cables. Anyhow, thanks for reminding me, I need to pull the tires and check them. I torqued them with a torque wrench. But yeah, they could possibly, maybe loosen up a tad. I only use the billet adapters from Wheel Adapters.com. No way am i trusting El Cheapo Chinese castings. I've seen and heard horror stories about them. Breaking. Studs coming loose when trying to tighten or loosen lug nuts. That would be a horror story!
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
If they are loose. Take the lug nut off and apply some blue thread locker. The lug nuts haven't moved on my trailer since I installed the 2" spacers on my trailer 8 years ago. When I switched from 12X4.80 tires to 205/65-10 tires and wheels.
cbxer55
767
I've run these adapters before, they have never come loose on me.
What I was talking about above was the studs spinning within the adapter while you're trying to tighten or loosen the lug nuts. Once that happens, you have a lug nut you cannot get off because the stud itself is spinning. Then you're in trouble. Guess all you can do is drill out the stud until the nut falls off. What a PITA that would end up being.
sgtsandman
12,651
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
cbxer55
767
What if, like my Mustang, the lug nuts are deep in wells on the rims? That isn't going to work. Always have to think of the worst case scenario. ;-)
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Thats not a problem, it will cut through a rim.
MrGearhead
16
Illinois
𝔽𝕠𝕣𝕕
𝟛.𝟘
Ok... finally got it right... Before and after. Now I have to install the new upper and lower control arms so I can get the alignment done..
