Eddo Rogue
- May 18, 2020
- 2,503
- Burbank,CA
- Ranger 4x4
- Engine Type
- 4.0 V6
- Engine Size
- OHV
- 2WD / 4WD
- 4WD
- Total Lift
- skyjacker front leveling kit
- Tire Size
- 31-10.50R15
- My credo
- Crossed threads are tight threads.
Not sure if correct category, but I found where my loose front end is coming from, but need help diagnosing whats bad.
When prying around, everything is tight except the front axle. The hub/rotor and outer wheel bearing is tight, but the inner wheel bearing seems to have play in it. You can see the axle wobble around inside the spindle. Would this cause my tire jiggle? I thought it was the ball joints, but they don't budge. I ordered Timken inner and outer bearings, races and seals. Am I on the right track?
