First thing You didnt take the time to see what sections THERANGERSTATION offers. This belongs in the V-6 forum. A mod will move it shortly.
Second, do you have a haines manual or any type of manual that offers troubleshooting advice? I would invest in one. If its not starting follow the trail one step at a time. You changed wires. Have you tested the coil? Does it have spark? Does it have fuel? Fuel flow? Have you changed the fuel filter? Have you checked you fuel pumps?
THe only thing required to make it turn is the starter basically. But to get the fuel to the cylinder and have the spark set off at the proper timing requires alot. Have you checked the timing belt/chain? I would take a timing light to it. Also I would take 30 bux to your auto parts store and invest in an OBD I test kit.
Last thing I can suggest, go read some fo the tech articles in the tech library. The fact that you posted an engine problem in the Ranger NEws Section, tells me that if you don't fix one major problem you'll never get your truck running. Attention to detail. Most likely its sumthing small that is preventing your truck from running.
Please don't think I'm being rude, but someone once told me the same thing. I learned alot from it.
