94Reborn
- Apr 23, 2012
- 1
- Engine Size
- 4.0
My truck is running rough at idle and under acceleration. It seems like a misfire, a timing issue, or maybe even a cylinder not firing. After checking and double checking everything I noticed my blinkers wouldn't blink either but were only lighting up solid. I found a loose ground, I believe its called G101. The ground on the radiator support drivers side by the edis module. After tightening, the lights now work like normal but engine condition is unchanged. What components are affected by this ground?
It is on the same part of the harness as the MAF, EDIS module, and PCM but I don't know if this ground has anything to do with them. I switched the edis as I have a spare and that did nothing. I unplugged the maf and it runs the same, and I opened up the pcm and it doesn't have noticeable internal damage. HELP?!
