What options do I have for an axle?
powerranger262
6
Wisconsin
I have a 2002 FX4 automatic. I blew the rearend the yesterday morning. I have been searching around trying to find a used rear axle assembly to swap in, but am not getting any luck finding one. So what I was wondering, is what other axles would I be able to swap into it to get it on the road again.
There are two axle tags on it. One says V305E. The other says 4 L 10 88 2003.
If I don't have to have this fancy, peice of shit torsen, I don't really need it. I don't hardcore offroad the truck, don't plan to. I just need to get to work, and tow a mixer or a two place snowmobile trailer once in a great while.
I've heard to stick with the 31 spline axles, but am not sure what other years will still work. Like I said, I just need this truck to get me to work. Any help would be greatly appreciated. Thanks.
Mac
183
C. Wisconsin
2000
199
Well these numbers 4 L 10 88 say it's a 4.10 L/S with the 8.8. you've got an auto and depending on what you were trying to pull shouldn't have had anyproblem. Try auto-part.com for something close with what you need.
DAve
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
There was a recall on the '02 FX4 Torsens, although they effectively weaseled out of doing the recall on auto trans trucks because "it didn't stress it as much" :rolleyes:
Needless to say they still break, just takes a little longer.
Swap an 8.8" Traction Lok L/S unit in there from an Explorer or F-150 axle. Should fit in there no problem provided the housing isn't damaged.
powerranger262
6
Wisconsin
Yeah, "weasled" is the exact word. When you say explorer, don't I have to weld new spring perches, and get a new brake booster for the rear discs that come on it? I'm looking to just take out the old axle, whole thing, and roll in another one.
What I'm getting at is what other rearends can I put in there? Would a 3:73 ratio work from another year, and what years? I just want to find the first thing, with low mileage, to put back in there.
TimV
4
Maryland
You are going to have to find another fx4 axle to roll under it, or rebuild yours. The problem with other ranger axles is the tube diameter is different, so you you have to get different U bolts and spring plates. Also, you would have to make sure to get a 4.10 ratio one. Overall strength would be decreased by going to a 28 spline from a 31 spline as well. I would look for another fx4 axle if possible.
11
Cheaper and better to rebuild. A used axle is still likely to do this again at an inopportune moment. Swap in just the limited slip differential case from an explorer and use all new bearings and seals, along with new fluid and additive. If you dropped to a 3.73 ratio, your four wheel drive would then be completely useless, unless you also swapped in the front differential and gears as well. How exactly did you "blow" your rear? Did it literally explode or did i just start making lots of noises? Did it stop pulling or did it completely lock up and slide the truck sideways?
Have you pulled the cover to see what the trouble is yet? Why are you so hell bent on replacing it when it could just as easily be fixed?
powerranger262
6
Wisconsin
It started making noises, first humming, then a loud howl. I went to accelerate from a stop sign, on a hill, and it just went bang. I put it in 4 wheel drive and nursed it to my boss's house. The whole time it was banging and binding if I went over 3mph. When I turn left or right it was really bad. It's been sitting there since Monday morning, haven't pulled the cover yet.
I want to replace it with a used one for my truck, but as you may know, it's not easy to find it.
I've never pulled apart a rearend before, and would just like to replace the whole thing. I kind of figured that I will have to find one just like it.
As for why, I've seen them from $200 up to $550. It would be at least that much to get it rebuilt.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
The only bolt-in options are going to be either another FX4 Torsen axle (later ones will of course be stronger post-recall units), or downgrading to a 28 spline axle (like was said, smaller u-bolts & spring plates will be needed to bolt it in).
4.10 Ranger 8.8 axles started appearing in '98 & up trucks.
powerranger262
6
Wisconsin
Thanks, that's what I was wondering.
powerranger262
6
Wisconsin
Sorry, another question. This is the description from LKQ. 2007 rear axle ford ranger, 8.8 GEAR, 10 BRAKES, 4NL10 EXC. FX4. And another, 1999 ranger, 8.8 RING GEAR, 10 BRAKES, 4.10NL. This was a search for a 2003, because I figured that the 2003 on my tag means it's from that year.
When I search 2002, which is what my truck is supposed to be, the only option close to my V305E tag is 8.8" ring gear, 10" brakes, 4.10 ratio, tag V305C, H, J & K.
So the one from 2007, I figure the "NL" means non-limited slip. It doesn't bother me, but would it work?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
If you input for a 2003 FX4 "Level II", you should get similar results as for your '02 FX4 ('03up FX4 (non-Level II) trucks use the standard 28 spline axle).
Any Ranger axle should physically fit your truck as long as you have the correct bolts & plates for it.
Not sure on the "NL" part. I would think the words "limited slip" would appear in the description if it was.
07rangerfx4lv2
Ontario, Can.
ford ranger
4.0l
i too just blew my rear axel, so all fx4 axels are the same a level 2 axel isnt different is it??
powerranger262
6
Wisconsin
Not sure, but start looking for one now. I looked all over for a month, and finally found one, and the only one, that was around WI.
powerranger262
6
Wisconsin
I checked with a local shop to rebuild it, and they would rebuild with an Eaton for $1400. Paid the $550 for a used one and did it myself last weekend. Gotta say that everything went really smooth.
