What interior lights on 1998 Ranger?
DavidG
Seattle
Ranger 4.0 4x4
Hi everyone. Bought a 1998 Ranger 4.0 XLT 4WD 5sp about two weeks ago, and have questions about the interior lighting. All the dash lights are out and fuse #33 looks good and I've ordered some bulbs and that will hopefully do the trick.
However, and I searched the forum for answers, I'm not sure what else should light up. For example, the HVAC control area doesn't light up and neither do the door lock and window switches on the doors - but I don't know if they should. I also couldn't find anything in the manual about all the interior lights.
Is it documented somewhere where all of the interior lights are located?
Also, when press the cruise control "On" button, nothing lights up on the instrument cluster. However, i do see "Speed Cont" light up when I press "Set" on the cruise control. Should anything light up when the cruise control is turned on?
Thanks for your help
David
sheep herder
1,024
sheep pen
If it ain't broke, break it.
On my '11 Ranger, cruise control light only comes on when cruise is engaged. Just pushing the on button doesn't turn on the light. For your other questions, you need someone familiar with a '98 model.
DavidG
Seattle
Ranger 4.0 4x4
Thanks for the info @sheepherder
David
55trucker
183
Oshawa, Ontario
3.0L
mild
Instrument panel dimmer switch active?
DavidG
Seattle
Ranger 4.0 4x4
Thanks Steve. Yes, the dimmer switch is active.
Can you please let me know what lights up in the instrument when you turn your key to the "on" position? My '98 is 4x4 and I would have expected the 4WD Hi/Lo to light up but it doesn't.
On my '98 Ranger 4.0 4x4 5sp, this is what lights up when I turn the key to "on".
  • check egine
  • check gauge
  • brake
  • battery
  • airbag
  • door ajar
Thanks Steve
david
55trucker
183
Oshawa, Ontario
3.0L
mild
See the pic.....my door ajar obviously will if the door is open, airbag also comes on (out of screenshot)
sheep herder
1,024
sheep pen
'98's don't have many idiot lights. My '11 lights up like a Christmas tree when I turn the key on. :LOL:
55trucker
183
Oshawa, Ontario
3.0L
mild
I like xmas trees.......
more lights the better.....
I also like it when the wife continually blows fuses:icon_rofl:
DavidG
Seattle
Ranger 4.0 4x4
Thanks for the response 55trucker. My airbag indicator also lights up. Is your Ranger a 4x4? I'm not sure if the 4WD Hi & Low should light up when the key is turned to the on position, but mine don't.
thanks,
david
55trucker
183
Oshawa, Ontario
3.0L
mild
it's just a 2wd........can't comment on the transfer case range lamp
