what gears do i have?
90rangersuper
Pittsville,WI
I have no clue what gears i have, looked on the tag on drivers door, by axle the number under that says 85, it is a 90 ranger with the d35 ttb up front and the 8.8 in the back, if you need more info just let me know, i will find out, should be stock gears, it was a old lady who owned the truck b4 me :icon_twisted:- you never know though,
Muddycowboy
GOT MUD?
Randolph, OH
look at the metal tag on the axle
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
According to the tech library 85 isn't a code used in rangers.
Sunk
125
Everett, WA
3.5 Eco
Maybe 95 or R5? Both are 3.55, R5 is L/S.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
'90 seems to be an odd year before Ford figured out their codes.
85 = 95 (3.55)
90rangersuper
Pittsville,WI
i swear that is says 85 on the door tag, i will double check though, i know its not a l/s because i get that wonderful one wheel wonder effect doing burnouts, as for that metal tag, where abouts would that be located? If it is 3.55 gears what would be the max tire size I could put on there
rickcdewitt
5
nor-cal
4-0 swap
the tag is held on by the diff cover bolts.
90rangersuper
Pittsville,WI
the door tags says 85, checked on the axle, pretty rusty, was able to make out 3.55 though
