What do you hate about your Ranger?
BiggSherm1988
U.S. Military - Active
57
Germany
Ford/Ranger
none...yet
not for me
Only thing is the fact that Ford did absolutely nothing to stop or even slow the effects of rust.
sgtsandman
Aircraft Fuel Tank Diver
Ham Radio Operator
12,739
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Sonic03
BFLO
There wasn't too much I hated about most of my Rangers.
My '99 had a way of popping out of, or grinding into second gear under hard acceleration, but it was fixed under warranty per TSB referring to a bad synchro.
For the '01 3.0L vulcan it was the graininess of the engine and lack of responsiveness my '99 Flex-fuel engine had.
For my second '01 w/2.5L, it was that it was neither of the previous 3.0L engines.
As for my '03, the only thing I'd have changed would have been to have a more modern seat which allowed some height adjustment, at 6'3" I just sat too high and had to recline the seat back a bit more than I'd like to have.
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
I hate that I've let it sit for a few years without wrenching on it. I even told myself THIS is the year to get to work on it. So far, all I've done is put it up on jack stands on every corner. Getting tires will have to be my first move , so I can actually move it to a better location in the yard to work on it.
Did Ian get ya?
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
Did Ian get ya?
Yeah, Ian, that's it. Ian is why I didn't do anything. LOL
I have NO excuse, except the D21 gets the attention that should go towards getting the Ranger back on the road.
Nah, we were lucky and all of the bad weather got sucked away. Since Ian first hit land, we've had beautiful weather and I've been at work for most of it. This past weekend was my 12th anniversary and I spent most of the weekend being with the Mrs.
superj
2,667
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
for sure, whoever said the 3.0 should only have a standard transmission in the ranger is right. mine is a really decent truck with the five speed and the 4.10 rear end.
rusty ol ranger
2.9 Mafia-Don
7,626
Michigan
177 CID
mikkelstuff
469
Brighton, CO
3.0L
All true with the 3.0L Vulcan. I had a 3.0L in a 2002 Merc Sable which was really a good runner. Just not so in my 2002 4WD automatic Ranger. As for a Cheby LS swap - NO WAY!
Junk Collector
Truck of Month
4,851
Rapid City SD
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
I was just kidding about the LS lol....Although a coyote might fit....
JoshT
1,800
Macon/Fort Valley, GA
The 2.0 was a joke too.
Yes, but...
The only engine that would have been more of a dog than the 2.5 Lima would have been the 2.3 Lima. Well, maybe one of the diesels but those weren’t exactly common.
What makes this one so sad is that there was a fix for it. Ford did it in other production vehicles. Would have been so easy to add on the boosty bits and make that a good engine. That's what I'm going to try to do in the not too distant future.
Bill
898
Sacramento, CA
After owning four of them:
I'll agree with the cabin noise. The wind noise isn't that bad unless you are breaking the speed limit. It's the road noise.
That rattle in the passenger side door is probably the door latch. I've replaced three of them over the years and it resolved the rattle all three times.
I'm always hearing weird noises. I think most of it is due to not having any sound insulation.
Regarding engines:
Earlier models didn't have much power because that was what you got back then. The 4.0L V6 was fair. The 2.3L Duratec is excellent for what it is.
Fuel economy mostly sucks. Depending on your location, climate, and driving habits, fuel economy on the freeway is mostly 18-23 mpg, and that is for all engines except the Duratec. If you are going to step in and tell me your 2.3/2.5L Lima is netting you 28 mph, I'm going to reply with you need to learn how to calculate fuel economy. The only advantage the Lima had over the V6 was that it got 18-20 mpg around town.
What was the point of keeping the 3.0L around after the Duratec came along? When I was shopping for the Ranger I had now I had trouble finding one with a 4cyl. There were plenty of 3.0s around, but they really weren't any better with power output and the fuel economy was poor.
Regarding the Duratec: It's a great engine and overall, probably one of the easier ones to work on. The exception is the location of the PCV valve and the EGR valve. Access to the PCV is difficult, and the EGR can't be accessed without tilting the transmission down. There's also a coolant bypass hose that required the transmission to be tilted back (or removed).
Other than that, all the engine options are fairly reliable.
Transmission:
This is my opinion, and I've come across other posts where people share my opinion, so here it is: The M5OD is a pain in the ass. The input shaft bearing wears causing play that damages the pilot bearing, which then causes difficulty getting into gear. I had to have mine rebuilt and it cost a fortune because sometime around 2001 Toyo decided to change the $35 single piece 2nd gear synchro to a $535 two-piece synchro. Then I had a scraping noise appear that appears to have something to do with the shift rail assembly (the noise changes when you move the shifter). The transmission shop couldn't figure it out, so they swapped another rebuilt and now I have the same problem again. Do a search for M5OD scraping noise and you will see this issue come up with every vehicle that has used this transmisson going back to the Bronco II, and nobody knows what is causing it. In contrast, I've own a 73 Capri, a 1975 Capri II with Borg Warner 4 speeds, and a B2200 with an M5M. All of them exceeded 160,000 miles without any transmission issues (other than replacing the clutch). The Capri had over 240,000 miles on that transmission. I started having problems at 90,000 miles on the Ranger. I'm also on my 4th clutch master cylinder (I think it the heat here is contributing to this problem), which wouldn't be so bad except bleeding these things takes more patience than I have.
Robertmangrum.rm
Wannabe Overlander
1,635
Tennessee
2.3 EcoBoost
2.5 level kit with rear add a leaf appox. 1.5
305/70r17
Buy it, build it, and drive it like you stole it
The payment 🤣🤣🤣
Eddo Rogue
2,503
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
dvdswan
2,904
Seattle, WA
Ranger XLT 2WD
It's not 4WD. Other than that, it's 30 years old and drives like a dream. As soon as something is wrong with it the Ranger will start looking like this...
