G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
And so, my fellow Americans: ask not what your country can do for you — ask what you can do for your country.
My fellow citizens of the world: ask not what America will do for you, but what together we can do for the freedom of man.
and why did I quote JFK?
ericbphoto
Overlander in development
16,603
Wellford, SC
6"
I think I'm worthy of being quoted.
ericbphoto
16,603
Wellford, SC
6"
jelinski
6
Mazda
I have a '94 Mazda B4000 (rebadged Ranger with 4.0 liter engine). For a long time (years!) it has seemed like the air conditioner does not blow as hard as it should. The blower sounds like it's running OK, just not much airflow out of the dash panel outlets.
Today (after putting if off for years!) I finally got in the right mood, and dug into it. I pulled the air cleaner and coolant overflow/washer fluid tank out of the way, and removed the blower, intending to check and see if the blower motor was running properly, and to see if it was getting full voltage when on high speed.
Removing the blower, I saw bits of leaves in the ductwork. I removed the dropping resistor assembly, and it was FULL of leaf bits! The blower is fine, the AC evaporator core was stopped up with leaf bits!
I used a shop vacuum (with the hose at the blower passages) and compressed air (blowing in at the dropping resistor pack opening) in the heater unit housing, and blew/vacuumed out all the leaf bits. Used a piece of rubber hose on the air blower for flexibility, then a piece of plastic tubing pressed into the end of the rubber hose as a blower tip, and was able to flex this nozzle all around to blow out all the leaf bits. Used a flashlight and a 'mirror on a stick' through the blower duct to inspect the entire surface of the evaporator core and make sure it was all clear.
Put 'er back together and now it flows more air on 'low' than it used to flow on 'high'.
Not a big deal, but a nice little evening project with a good result.
That's what I did with my (rebadged) Ranger today!
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
You’re lucky the leaves didn’t catch fire from the resistor.
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
8,745
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Alan_nc
140
US
Ranger Splash
Finally got the drive shaft back in. Took Floyd for about a 10 mile run. Seems to have gotten rid of some vibrations.
Hey....I'm happy anyway.
ThatOneGuy
575
South sound
Ranger Explorer
Explorer is 4.0 ranger is 2.3 soon to be 4.0
Let the universe take you where it will !!!
I recently bought another 83 ranger 2.3 4x4, my original was a 2.8 but has sat for ten years now, I have a good running truck but she is rough around the edges. Iv'e been stripping the entire interior dash frame included going to go through wires with a fine tooth comb damn tweaker wire mutilation. Gotta replace fuse box clean,deal with surface rust as that's all there is even original floor pans are solid as new. Truck does look like a pine tree died in it though needles and dirt everywhere. Once clean and repainted I have a nearly perfect full interior out of my 85 I will be installing. I figure with my three trucks and one title I should end up with a really good truck. As long as no one hates on my meticulous rattle can paint job. It can be made to look and last well if done right. Done it a few times.
ericbphoto
16,603
Wellford, SC
6"
In preparation for the trail ride, I loaded some parts, extra fluids, tools, etc. In the new toolbox I had mounted in the bed, tweaked the alignment slightly to center the steering wheel and give a bit more toe-in and drove it to pick up Chinese takeout for dinner.
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
I don't count birthday's anymore...just happy to be looking down at the ground instead of looking up
Bought a set of side step bars from Amazon. Spec D 3 inch. Wife gave me permission to spend a few $$$.
I know there mostly useless but I always liked the look. Delivered next Wednesday.
Uncle Gump
Token Old Guy
13,478
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I remember when you bought your truck... the goal was completely stock... and you were going to keep it that way. lol My how things change. It's hard to not modify...
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
Hard not to mod these things. Don't think I've ever owned a vehicle that I didn't do something too.
But, I do get a lot of "thumbs up" :icon_thumby: when I'm out driving...even from "the others" owners. Even had a Chebbie owner try to buy it from me.
Havent posted in the how too's too much cause I haven't had any problems at all. Guess I'm lucky, and that I have a bit of $$$ to throw at it.
But, I do admire and respect all you members who keep the old one's going, doing your own heavy mods, rebuilding and renewing. You all have some great skill
set's, and a wealth of knowledge. :icon_cheers:
