Vunotbu
- Dec 1, 2020
- 0
- Texas
- Ford Bronco 2
I bought this thing about a month ago and I was driving it and it just stopped working, it was a distributor cap that broke so I got it fixed, but now it doesn’t make it for more than a 20 minute drive without dying, i would drive And it would work fine then i would stop and if I stopped for a while it would shut off and won’t turn back on and if it did it would have almost no power and it would come in little sputs and then die out again ... if I let it sit for a day or two then it cranks up again just fine. It seems to be a problem when the engine gets a little hot but my gauge seems to be working fine
UPDATE:
Now it won’t turn on at all going to replace the tfi module then see if it changes anything
NEW UPDATE:
I replaced the tfi module and it is still stalling out and not starting when it gets a litle bit warm. Any other things it could be? Or did i not put enough silicon heat sink or did i not bolt it in right?
UPDATE:
NEW UPDATE:
