weird overheating issue
MrE_Powers
12
st. chuck county, mo.
3.0,4.6,2.8
this is on a 198 4 b2 with 2.8 durasparked
it seems when the outside temperature is below 32 degrees it over heats but when it is warmer then 32, like say today it is 65 out it runs in the r in normal even after i pushed it hard. i can only think fan clutch. but i dunno what to think. no body i have talked to, have encountered this problem. so any input would be very appreciated.
kimcrwbr1
46
maplevalley WA
2.8l
Do you have the t-stat in the lower radiator hose or the upper one. I found a t-stat housing two piece that goes on the intake manifold I believe it came out of a 85 B-II with A/C. It could very likely be the fan clutch only one way to find out. I know mine did all kinds of weird stuff until I put the thermostat on the upper hose I found the best way to fill the radiator is to put a flushing tee in the heater hose that goes to the intake manifold pour the antifreeze and water in there until it fills the radiator. It takes longer but it fills up the heater core and bypass, it can be a pain getting rid of the air locks in the system.
MrE_Powers
12
3.0,4.6,2.8
my pop said he tried a range of t stats in the lower housing. i thought that the upper hose may have had a t stat in it. because of my 3.0 ranger. but he said no. he also said that he went through and installed new sending unit and gauge. to see if that was the issue. but that since he had the b2 it always ran hot when it was colder and fine when it was warm.
jhammel85
Guest
I think that if that doesn't work, you should try a new fan clutch. You could be right about that..
big red 138
Virginia beach, VA
see if you can stop the fan clutch by hand, if so its bad. but if its cold out the fan clutch shouldnt cause an overheating issue, especially during cold weather. all it does it pull air through at idle, while your cruising the air flows through the radiator and itll be fine.
whats the condition of your collant? lots of rust, debris? radiator filled partially or entirely with water? if the tempeture is freezing it could (<-- keyword) cause the coolant to freeze, which could restrict the thermostat from opening all the way, long enough for the coolant in the engine to overheat. try flushing the radiator and add pure antifreeze( there will still be water in the block to dilute it, so you dont need premix). you could also replace the thermostat, both are very cheap and dont take long.
jhammel85
Guest
You can tie a string to the fan and achor it on something sturdy instead of using your hands. At least that's what I did.
MrE_Powers
12
3.0,4.6,2.8
Clogged radiator seemed to be the problem once it was changed out i drove it 20 miles and no issues and was o between o and below r on NORMAL where as before it when it was before it was between the bottom of n and o. they did put the thermostat in a bad spot though.
big red 138
Virginia beach, VA
true, i have a set of gloves in my box so i usually just trow it on real quick... i think the thermostat and water pump are in a great place.... niiice and easy to get to
MrE_Powers
12
3.0,4.6,2.8
water pump....thermostat should be in the top like the 3.0 though in my opinion
kimcrwbr1
46
maplevalley WA
2.8l
If the rusty water comes back it will just plug the radiator again it settles in the low spots in the block and will always be a problem. There is a thermostat housing that fits on the intake manifold. It is a two piece housing with a 1" bypass hose, I believe they came on the 85 B-II with A/C. Your correct the thermostat on the lower hose was a bad idea. I got lucky and found mine at the bone yard looking for a carb. The only way to get rid of the rust is pull the water pump and with high pressure water blast out the block. The rust also prevents the heat to transfer properly from the block.
kimcrwbr1
46
maplevalley WA
2.8l
You can kind of see the housing
big red 138
Virginia beach, VA
youll still wanna run some flush. like kimcrwbr1 said, more then likely that shits throughout the rest of the system.
MrE_Powers
12
3.0,4.6,2.8
i replaced the radiator and all of the radiator fluid that came out was green as green as can be. i replaced it with new stuff.
