- Jan 12, 2021
- Reaction score
- 827
- Location
- Walkerton Va 23177
- Make / Model
- Ford Bronco II
- Engine Type
- 2.9 V6
- Automatic
- 2WD / 4WD
- 4WD
- Total Lift
- 3"
- Tire Size
- 31x10.50R15
Can someone direct me to the procedure for 2.9 valve adjustment? I can't honestly recall when I assembled the engine if I soaked lifters or not, I'm going with yes. Anyhow, when the truck is "cold" started (basically overnight) I get a decent amount of valve/lifter noise for 5-15 seconds of run time. Wondering if I have them too tight, and causing lifters to bleed down too much when it sits? I took lash out and turned in 1.5 turns, with an angle gauge, I have not doubts about my setting, but I wonder if doing it cold or if lifters were soaked or not caused too much difference? Seems to run 100% fine after the initial 10 seconds.. any suggestions?
