"Unnaturally Aspirated" LS Ranger
surfer5567
Law Enforcement
Completely forgot about this thread. Truck runs and drives. I'm currently waiting on my aluminum rad to be done. Probably Thursday.
It's super tight and I had to make my own manifolds. I ran out of patients and they didn't turn out pretty but they work. LS7 manifolds are the tightest stock manifolds to the block and they wouldn't clear the steering shaft with the engine offset to the pass side.
Could the steering be moved to the outside of the frame rail? Would it clear then? Like I said only reason im so stuck on stock working is our stupid smog laws here
Alix
Michigan
5.3 Turbo
Anything's possible with enough fab work haha.
Easiest thing I could think is maybe a wrangler steering gear. Those mount to the outside of the frame. Even then the manifolds would probably have to run outside the frame rails
insane4speed
mass
Damn that is close. Would it be the same clearances with a 93 explorer
insane4speed
mass
do you have any pictures with the headers installed?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
trying not to derail your thread alix, but you may have to club me for this.
if you roll about 1 inch out of the frame rails the e-rod type manifolds look perfect and according to spec fit awesome....http://www.jegs.com/p/Hooker-Headers/Hooker-LS-Cast-Iron-Exhaust-Manifolds/1918563/10002/-1
i dont see too many issues.:dunno:
i wish someone local would bring me one to do a swap on. i have offered and got close, but never panned out yet. same thing on a 5.4.....i would need some serious time for one of those though.
granted this twin turbo build alix has is out there...or not actually for an ls, (its out there for a junkyard 351, 302 or 350 because it would be a ticking time bomb before it split in half)...but he is also doing it with very tight restrictions using stock steering location and rag joint and low/no body lift etc and wanting it to be sleeperish.
for a sas or lifted 4x4 rig its not too bad. stupid easy maybe...
by my measurements from a jeep swap back in 01-02 i had it figured a bit more difficult (van manifolds on donor ended up with camaro stuff iirc)....but after seeing several ranger and s 10 trucks and mustangs in person, it looks quite a bit easier fit wise then originally anticipated for sure. the fead is limited and i dont like a aluminum pan at all for a wheeler but it can work no matter what.
great pics here with various applications. http://www.holley.com/8501-3HKR.asp
this style flipped for twin turbo would be cool looking too....
anyway, like the stock truck manifolds the hookers are supposed to be really nice to cut and weld. i seen the cut and reworked manifolds in a ranger(strip application) and several other vehicles at koh last year.
at the fast ford weekend several years ago there were several mustangs with their original headers reflanged, and some had the 351 windsor distributor setup and big carb on top. some lower budget builds were 10 second door slammers on radials through quiet mufflers with ac. guy claimed he was under 5 grand total including buying the car....:icon_idea:
and people wonder why i like the platform:icon_confused:
not sure if reflanging your 302 early bronco or fox 351 headers would be a cost effective way to get exhaust in a ranger with a ls type engine or not but its a option.
only one way to find out.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
AgPete139
09/2014 OTOTM Winner
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
He's been gone for a while...
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
How this didn't turn into one of those builds that starts and never gets finished.
Sent from my SPH-L710 using Tapatalk
lsxRanger94
5.3
I was hoping for an update too. I'm getting ready to start my N/A 5.3 build. This one inspired me.
