U joint confusion
StephenLewis
Goshen, Indiana
Big Bad 2.9L
My carrier bearing it toast and I'm lookin at throwing a one piece shaft in there just as an opportunity to upgrade. I have the stock transfer case and rear end. Would the new driveshaft use the same size u joints or would I need a conversion joint?
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
If you get a '98-'00 steel shaft, it should bolt right up to your flanges.
The later '01up aluminum shaft will require you swap your t-case output flange for a larger one. Both shafts will require you trim the skidplate under your fuel tank for clearance when the suspension flexes (the aluminum one more so).
See this article:
http://www.therangerstation.com/Magazine/June04/offroad.htm
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
You can also use a 4x4 explorer sport trac steel shaft from 01-05.
StephenLewis
Goshen, Indiana
Big Bad 2.9L
Thats what I needed to know. Thanks guys
