- Dec 6, 2007
- 1
- Age
- 52
yeah it is just like MP said, the turbo raises the cylinder pressures which is why if you start off with lower compression pistons, which are forged you have a stronger piece and it can stand more boost. the real enemy in a poweradder motor is detonation. you see, any poweradder weather it be nitrous, supercharger, or turbo packs more oxygen and fuel into the cylinder at a give level than a N/A motor can just suck in.
nitrous... N2O... 2 parts nitrogen (inert gas, stabilizer for the oxygen) and 1 part oxygen. a typical nitrous kit injects a metered amount of nitrous and adds the proper amount of fuel for the nitrous it is injecting either a "dry" kit or "wet" kit.
supercharger... uses crankshaft to drive a belt driven compressor (adding parasitic loss, w/o lag) to compress the incoming ambient air and adds fuel enrichment.
turbocharger... uses exhaust gases to spin a compressor (no parasitic loss, but has lag) to compress the ambient air and adds fuel enrichment
notice all of the poweradders add 2 primary things oxygen and fuel, they do it in different ways but the end result is, more of a combustable air fuel mixture making a bigger bang (depending on how much bigger the bang requiring forged pistons). this is an oversimplified explanation as there are alot of other variables, such as timing. with ANY poweradder timing MUST be backed off in stages to match the extra power added... if it is not, detonation is the result... we could go on for days explaining detonation, simply put, it is when the air fuel mixture in the cylinder explodes at the improper time in relation to the stroke of the piston as it travels thru the cylinder causing catastrophic failure. i know you didnt ask for all of this, i just figured i would cover all the bases, im sure you probably aready knew some of this, i figured it might help some of the people reading the post.
detonation can also be increased by not adding the proper amount of fuel to the mix, rich condition adding too much fuel.
*NOTE* maximum power is reached right on the edge of detonation, so being precise is of utmost importance!
