Transmission Rebuild Question
cubewhiz
Kearny, NJ
2.9L V6
1"
31x10.5R15
This question is specific to the SM465 transmission (a GM transmission), but general enough that it likely applies to other transmissions as well. Thus, I figure that even though it is not from a Ranger, somebody on here can probably answer this anyway.
I have a couple of gear/bearing pullers, but they have proved useless for pulling the front and rear bearings (see below). I need something that will fit in the outer snap ring groove of the bearing but will also have a long enough reach to offer counterpressure on the shaft. Thus, the reach needs to be a bit over 6 inches. You'll notice, also, that the bearings are pretty large.
Who makes a bearing puller like this and where can I get it? Ideally, somewhere that I can go and get it so I don't have to wait for it to ship...
cubewhiz
Kearny, NJ
2.9L V6
1"
31x10.5R15
Never mind, I wound up buying a set of Posi-Lock TJ-1 that worked beautifully. :)
