Transfer Case speed sensor part number
Deucebarajas
Ca
Can’t find part number or description any where on highlighted area.
Anybody have it???
1991 Ford Ranger 4wd.
36192
Josh B
1,987
Oklahoma
It appears he found it and never came back man :/
Josh B
1,987
Oklahoma
Add a post of your own, borrow this old picture if you need to, and ask if anybody knows :)
Fordracing232
Latrobe pa
Ford ranger xlt
🤣😂 apparently, I just might do that, I think I know what it’s called but I can’t find it anywhere
Josh B
1,987
Oklahoma
I clicked like on his post, he should get a notification, maybe that'll get him checking in again
Sdude2008
18
Farmington CT
3.0 Flex
31x10.5x15
Related question. I need to replace my TC motor but nothing I see listed matches mine. I have an extra wire which runs to a pin near the output shaft base. The motor pictured in this post is close but mine has only one wire. I pulled gently on it and it doesnt come off. Any info is appreciated. TIA.
Fordracing232
Latrobe pa
Ford ranger xlt
So Ford really went out of there way when they designed this setup.... you will never buy a 10 wire motor so what you have to do is be very careful like you are about to do brain surgery, no joke when you bust a retaining lock you will know what I mean 😂 cause well I already did it...... where them three wires meet at the connector you have to pull the red lock wire retainer in the plug then once that is pulled there will be plastic lock tabs that hold the wire in the plug, gently release them and put the wires in your new motor connector one at a time that way you know which one goes where
