- Oct 11, 2011
- 2
First time post so please forgive me if this has been covered before. Did a search, but could not find a specific answer. The 4.0 is new to me and I have not yet learned all it's tricks.
My 4.0 in my Ranger runs beautifully, does not smoke, but it does have a lot of clatter which, (I hope) is lifter noise. It also uses a fair amount of oil, 1 litre every two tanks of gas. I know the right answer would be to pull the engine and rebuild, or replace with a fresh engine. Money is tight and I don't have a place to pull the engine, but I was considering redoing the heads and valvetrain. It does have very high mileage, (350K Km's). The noise is definitely mechanical in origin. I've addressed the timing and carbon buildup problems that seem to be common. I've determined the noisiest part of the engine seems to be the right side valve cover area using a stethoscope. I am concerned that this could be a failing bearing as it does become more noticeable under load. I have replaced plugs, (# 2 and 5 were hopelessly fouled). Compression is even and oil pressure is good.
Any ideas as to how to confirm lifter or bearing noise without disassembling the engine?
