This just seems odd to me
Fryedbm
41
Ks
Should this grease be here? Wheel bearing need packed or replaced? Thoughts .....
rumblecloud
1,122
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
Question is a little vague, but:
If there's no grease, then yes, it should be there.
If there's no grease, then yes, it should be replaced.
If there is grease, then inspect bearing(s) for damage.
If there's no damage, then replace them anyway --- and make sure the new ones are packed with grease.
Fryedbm
41
Ks
I guess the question was.....should I be concerned it even looks like that? Should that hub be completely dry? Does that make more clear the question? Sorry
RustyShackleford94
Just some guy
355
IN
I picture would help. But no it should not be dry in there.
Blmpkn
Toilet enthusiast
6,359
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
The cap was probably re-used last time bearings were done, supposed to be replaced.
ericbphoto
Overlander in development
16,613
Wellford, SC
6"
This look satisfactory?
Hard to tell. I use a red colored grease. So, if I open it up and most if it looks brown, it's definitely time to change it. If in doubt, disassemble, clean, republicate and reassemble.
Fryedbm
41
Ks
Ty. Is it necessary to remove my rotor to replace any of this. (upper control arms,lower ball joints,sway links,inner tie rod and tie rod ends)
ericbphoto
16,613
Wellford, SC
6"
I don't think it's required. But it would reduce the weight of the steering knuckle/spindle and make that easier to manipulate. Last time I had all that apart, I was replacing the knuckle. So I had to disassemble everything.
Fryedbm
41
Ks
Ty
Fryedbm
41
Ks
I was able to take off axel nuts with my fingers. That's not right is it?!? As in.....no socket required!!!
ericbphoto
16,613
Wellford, SC
6"
The final torque on those nuts is just a few (10-15) inch-lbs. Just barely over finger tight. But there is a higher torque for seating the bearings first. You need to follow the procedure when you put it back.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
That nut only gets torqued to a MAXIMUM of 12 INCH pounds. So yes it should be around finger tight.
When you put it back together it needs to be done by first torquing the nut to 20 foot pounds while spinning the rotor, then back the nut off completely and re tighten to 12 inch pounds.
Fryedbm
41
Ks
Ty. I'm glad I asked. Does this all look good as far as you can see?
