Thermostat housing
Jimmyrig
Northwest oregon
2.8
It ain't stuck till it don't move
So I have a cracked thermostat housing on my 85 2.8. Napa can't get it, ford says it's discontinued. It's the two bolt style, the temperature sender and another sensor screw into it. Any suggestions on finding one or finding an interchangeable part? I will update this later with the original part number if that will help. Thanks in advance
Jimmyrig
Northwest oregon
2.8
E3TZ 8592N is the number for the original, it's the old stylethat looks just like one front a 70's v8, except for the sensors and it also serves a heater hose. Looks a lot like what a 2.3 from the same era has, just a little bigger. I would be happy with anything that will bolt on and seal, and just move the sensors and heater hose if I have to to get it back on the road
AndyB.
142
Cincinnati, OH
Jimmyrig
Northwest oregon
2.8
I'm starting to consider making an adapter plate,goING to the still available 3 bolt style
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
Have you tried junk yard? I occasionally see 2.8 Rangers and B2s.
Sent from my SM-N910P using Tapatalk
85_Ranger4x4
17,882
SW Iowa
Usually I see the older ones which I think is what the OP is after. The later style was a mid '85 change so it was only made for part of a year. If possible I would try to switch to that style and enjoy having the thermostat where it is meant to be (IMO)
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
The old style is really the one ones i see. Thats what my 85 had.
Jimmyrig
Northwest oregon
2.8
You guts must have good junkyards, last time I went to look the closest ones to me has 4 cylinders and 4.0's, a couple 2.9's and that was it. I have a line on a parts truck, maybe I'll get lucky and it will have it.
Jimmyrig
Northwest oregon
2.8
Update, j.b.weld and a flat file and it's drivable. A shortage of firewood and trees to close together for my chevy to fit led me to the backwoods engineering fix. I swapped some cheapo used 32's on it a while back bease my buckshots wouldn't smoother out. Did some cutting today and it reminded me how much I love these little trucks. Squeezing between trees and driving over rotten logs and small brush piles and yard in logs out it did great. The tires suck, but it still walked over everything, just didn't have the best traction for pulling. Of course it's a $100 dollar beater truck or it wouldn't be doing that, but it got the job done.
85_Ranger4x4
17,882
SW Iowa
It is hit and miss.
Last time I was there they had one first gen. It was too early for the switch I needed (it was a BII so it did have a 2.8 though I guess)
