Swapping LSD to open dif- any issues with a 4WD?
mustang9_92002
Indiana
Ford Ranger XLT
I have a 1998 Ranger XLT 4.0 4WD with an 8.8 3.73 LSD. Due to a minor accident I have to replace the entire rear end assembly. I found a cheap junkyard 8.8 3.73 rear end from a 1999 ranger 4.0 FWD but it is an open differential. Would using this cause any problems other than the obvious loss of performance of a LSD? Would it cause any issues with the 4WD? My mindset is that as long as its the same gearbox and ratio it shouldnt be a problem but I thought id throw it out there to minds greater than mine.
broncc
Ham Radio Operator
571
MA, USA
Ford Bronco II
5"
Giving my truck more money than it deserves.
No issue. You'll just notice a lot less traction.
mustang9_92002
Indiana
Ford Ranger XLT
Thanks for the confirmation. (y)
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
But isn't it true he can put a locker if he wants? With LSD you'd have to switch it to open to put in a locker, true?
dvdswan
2,906
Seattle, WA
Ranger XLT 2WD
Correct, as long as the gear ratio matches front axle and rear axle the 4WD system will work fine. Open, LSD, or solid locking devise in the carrier doesn't matter. You can add a LSD / solid locker later if you wish.
00t444e
217
Southern OH
Ranger ext cab
Yes a lunchbox locker goes in an open carrier, if it's a full case locker it doesn't matter since you are replacing the carrier anyway.
